Triple Rad in a TJ-06
Demon_of_The_Fall
Hey, I remember some guy had a thread here aages ago about how he modded his TJ-06 to take a triple rad, standing vertically up front. Can't seem to be able to find that thread anymore...
Anyone got any linkage to it, or to similar projects? I absolutely loved the mod and want to do the same myself.
if you cut out the 3.5" bays in the front theirs just enough room for a dual 120mm heatercore (dangerden). So i see no way a 3x120mm would fit
I think the only place where you can install a tripple rad is if you remove the HDD cage and place it along the horizontal support bar. If you want to place a tripple rad in the front, you'll need to remove the front 120mm fan assembly, 80mm fan assembly, 3-1/2" bay assembly and then cut into the 5-1/4" bay assembly.
I'm currently installing a DangerDen double heatercore in the front of my black TJ06 and it fits nicely.
A double core (this one's a Weapon 302) will fit easily up front....triple will be tough.
