Triple Mount Large Screen with smaller side.
itomwisp
First off, i have the following in my office.
TWO
http://www.newegg.com/Product/Produ...itors+-+LCD+Flat+Panel-_-HANNSPREE-_-24262014
ONE
http://www.geeks.com/details.asp?invtid=HF289H-PB-R&cat=MON
What i would really like to do is this.
Please note i will be buying smaller monitors for sides. If i can i wish to use my 27.5 with two smaller ones on the side vertically. I would like to led soon, so if i could plan for leds in the future would be nice. If the 27.5 isn't possible could i pull it off with one 25? I would like to buy a stand for them as well. Everything i have has mounts, my graphics card can handle it.
Anything i don't use i will be selling off.
Last question.
Does any one make a mount that can hold three 25inches?
The general recommendation for the side panels is going to be to use something with an IPS panel so that you can take advantage of the better viewing angles. LED or not, TN panels offer poorer viewing angles that are greatly exaggerated when rotated in portrait.
As for a mount, any mount capable of holding 3 24" monitors in landscape should be able to hold a 28" monitor and 2 smaller portrait monitors. Take a look at , ergotron, XFX for brands that make triple monitor mounts.
Lastly, you noted that your graphics card can handle triple monitor resolutions. Just a word of caution, I do not believe Nvidia or AMD/ATI currently have an acceptable solution to PLP (Portrait/Landscape/Portrait) setups for gaming.
Hope that helps
