2face-MazE
- Nov 5, 2004
I picked up another monitor from a friend at a dirt cheap price to replace one of my dual monitors. Now I'm thinking of still using that replaced monitor for a Triple-Display setup.
Here are my thoughts though, and I would appreciate some input:
I've heard that some old Voodoo PCI cards had different voltage requirements than what is provided by modern motherboards/power supplies.
My main video card (probably irrelevant) is an eVGA Geforce 6800 Ultra AGP for my current dual monitor rig. Here is the more important info:
Power supply: Antec TRUEBLUE 480 Watt ATX12v
Motherboard: Asus A8V Deluxe (NOT rev.2)
2nd Video card: Voodoo Banshee 16MB PCI (3D Blaster by Creative)
I know PCI vid cards that can perform and display a HELL of a lot better are out there and for a good price, but I wanted to see if it's possible to push this things life on for a little longer. Also, if any of you recommend not to use "Just-In-Case", then I'll follow that and be done with this card.
Thanks in advance!
Thanks in advance!
