Since my last posts got wiped .. I guess I will finish this off for the rest of you that care
This is a long time coming.
The build is technically done, but I am having some issues. The system is stable as can be, but I hear wierd sounds. Like, the video card makes the most awful whining noises when booting games. It seems to go away after a few minutes of play time, and I see no performance issues from it. I am told that other experience this (and have since the 8800 series). I Think I notice it a lot more because I have nothing to buffer the sound. It's in the open, and in mah face.
If I start having performance issue with it, I will send it back .. but for now I am fine with it.
The other issue is my Motherboard is not liking my RAM. I can only use 4 gigs out of the 6. I have (through many troublshoots) determined that the RAM is good, and the Motherboard is good. It is a dislike between the two that is causing the issue. I amd living with it for now, but I think that new RAM will need to be ordered.
Anyway, here are the pictures. I have some more of the finished product, but I need to make sure that those a good pictures .. and not like the ones I have already.
