Trilenear Optimization?
Should nVidia 6800 ultra tri linear optomization in the control panel thing be on or off, it is just that i read somewhere that when on it can decrease image quality...
also, is the ultra high quality setting that different from high quality, both in image and fps...
thanks
f
It does decrease image quality. How noticeable it is, depends a lot on the textures used.
In some cases you can't tell the difference at all, in other cases it will be reasonably obvious.
I don't think it will actually boost performance much on a 6800-based card though... although to be sure, you'd have to benchmark both options.
