Ocellaris
- Jan 1, 2008
First I tried a MSI R9 390 and it had bad coil whine anytime the GPU was loaded. Decided to go with a Strix R9 390 because I like the design and the card was almost the exact size I could fit into my case. Freaking loved the Strix design from the moment I pulled it out of the box. Got it running and survey says...
Fan rattle
https://www.youtube.com/watch?v=e8mv-mPhPIw
Cell phone camera is pointed down into the top of my case. I start the video at by going to 40% fan speed, then raise it in 5% increments. Rattling starts at 45% speed. Around 24 seconds in the fans are at 55% and you can really hear it.
Disappointed that I can't manage to get an AMD card without a bad flaw. This Strix is better than MSI on the coil whine, however this fan is going drive me mad. This Asus has coil whine as well, just nothing bad that I would return for. The Strix runs pretty hot at stock fan profile (which never goes above 40%) so I was using profiles in Asus GPU Tweak II. Sending back to Amazon, not sure if I am going to get a refund or replacement now. I can't fit a Sapphire 390 since my case only fits 304mm, this Asus is 300mm, the Sapphire is 308mm.
Fan rattle
