Sysjack
- Oct 6, 2003
I thought it would be cool to have a custom boot screen for my XP Pro with SP1 PC so I downloaded a few programs and themes. I used LoginUI Boot Randomizer and everything looked like it should work.
Well, when I rebooted it got to where it should have shown a boot screen, any boot screen, and froze. I rebooted and tried to go into safe mode, same problem. I cannot access a command prompt, or get into safe mode. I went into the XP Recovery console and replaced the ntoskrnl.exe with a backup, even though the program guide says it doesn't modify it. Well, I now see that I should have put the program and all the files with it in my windows directory, but it's a little late for that.
I have another HD with a bootable 98 install, but I have no drivers on that. It's from before I completely rebuilt my computer and I don't even get USB support. I have the keyboard, but it doesn't see my XP hard drive when I swapped them around.
In the XP Recovery console I can't run the bootbak.bat file that the boot screen program made in the event of a problem. I should just need to run that to make everything better, but I can't run programs in the console. I think if I could get into a command prompt or into safe mode, or anything, I could fix this, but I'd really like to avoid having to reformat either drive.
Any suggestions?
Any suggestions?
