Anyone ever experienced overclocks that can be stable for 24+ hours if you don't touch it, but otherwise, it's anybody's game?
When I clock to 8x450=3600 with my e6400 with 1.475v (no drop/droop) and ram 1:1 4-4-4-10 2.29v d9gmh on a p5b vanilla (did same settings on ds3 with identical results), I can prime small/blend/large for almost as long as I want if I don't touch the computer while it's going.
If I use the computer while it's going, there's a good chance there'll be a bsod (usually machine check) at some point. Today I got to the 14hour mark in orthos (usually I've found crashing at 8 and then 14 and then around 24). While I was loading a website, it just up and died on me.
When I'm at 8x400 with 1.325, I'm rock solid forever and a day no matter what I throw at it.
Temps could be a little better, and I'll improve them soon. But currently, I'm loading in the mid 60's. It used to be in the mid-upper 50's before when I used a different paste and room temp was lower.
8x400=3200 1.325v, I get load around 50 or so. All temps are coretemp.
I haven't measured vfsb or vmch on the p5b yet, so I'm not sure if they're setting properly. I did verify on the ds3 when I had same symptoms.
I've got a 120 spaced above the ram blowing down, and it's keeping them real cool.
psu is enhance 500w
Anyone have similar situation? Or at least an ability to be able to detect this error quicker, instead of having to orthos or otherwise use the computer for a day or two before it randomly crashes? Obviously, occt says it's stable.
psu is enhance 500w
