Alright, i'm playing Hellgate:London with the following specs:
E4300 @ 2.7 ghz
2 gigs ram
8800 gts
Should be more than enough to run high settings, right? Well i have a feeling that Hellgate is SCALING down because perhaps it thinks my cpu is too shitty to play high (They have some built in down-scaling program into it).
Now when i check dxdiag It says I'm at 1.8 Ghz (Which isn't true, since i'm overclocked). What i want to know is can i essentially TRICK the computer into thinking it really has 2.7 Ghz (Which really isn't 'tricking', since i am running at that frequency). Thanks! Oh and By the way, it really does display 2.7 ghz on 'my computer' but not in dxdiag.
E4300 @ 2.7 ghz
2 gigs ram
8800 gts
