brokenarrow03
- Nov 20, 2007
Is it possible to have 3 GTX 260's in Tri-SLI and a 4th GTX 260 dedicated to physics? Not really caring that it is probably massive overkill, just curious if it is doable?
Thanks guys, I am not terribly worried about room, I am more concerned with the setup. From what I have been reading on Nvidia's website is that the physx card needs to be a different card. Any reality to this...
4th card can't be the same as to what you use for tri-SLI.
Why not?
It never did for a customer of mine...
I've tried having identical cards in the motherboard and the software won't let you choose 1 for physx, at least mine wouldn't (maybe because i was in the 2nd slot, might need to be in 3rd). Anyways, If you have tri-sli, I doubt you would notice a boost from a physx card lol.
