Tri-sli GTX285OC's
bdubb
Anyone running, or can point me to benchmarks of BC2 running at 2560x1440 with tri-sli GTX285's and an i7 overclocked to 3.6?
I'm getting a lot of jumping in a busy game and I haven't done any changes yet to see if it's the cards lagging behind or the monitor. Monitor is a u2711 and I already made a thread in the displays forum and read a few of the 44 pages of the u2711 thread.
I don't have any benchmarks for you but at that resolution you might be running out of Vram. What level of AA do you use and have you played around with taking that down a notch?
Can't tell you without looking, but it's all set to the highest settings. I just made the assumption the 3 cards would run it at that. Haven't had the time to lower the settings yet although I understand thats something I should have tried to do first. Hope to give it a try this evening.
You're not going to be able to play it maxed out. First turn of AA (set it to 1X) and disable HBAO. If that's playable then try enabling AA or HBAO up to the point where the performance is still acceptable.
