Tri SLI conundrum
redmasc
I'm currently running a EVGA 580 GTX Tri SLI setup powering 3 Dell 30" monitors and they're in surround mode. Each monitor is connected to 1 card each. And the problem with that is that it will recognize all 3 monitors as 1 giant monitor. I need it to run in separate monitors for better work flow and need the Tri SLI for gaming. Having to resize windows is annoying since they go all over the place instead of going to 1 of the 3 monitors.
The other Tri SLI option connects all 3 monitors to 1 card and will see all 3 monitors as separate monitors. But will HDMI support the 2560x1600 resolution? I've tried with a regular HDMI cable and it only goes up to 1920x1200. I gave EVGA a call and they said that it does support the 2560x1600 resolution, but will need an HDMI 1.4 cable. Can anyone confirm this?
Avatardelta is right, change your SLI configuration to "Maximize 3D performance." Make sure your middle monitor is connected to the first port on your primary card so that your middle monitor is you primary screen for both non-gaming and gaming. The remaining two monitor's display cables should only populate the first two cards leaving the third card empty. This configuration should allow you to use tri-sli for gaming while allowing your OS to see three monitors rather than one.
Doesn't work. It only recognizes 2 monitors since they're connected to the first card. The 3rd monitor is recognized but will not enable. When I go to set up multiple displays and check the box for the 3rd monitor, I get this message:
When SLI is enabled, only one GPU in the SLI group can drive displays. To use two displays, connect them to the same GPU.
You could download matrox powerdesk for free and set it up to cut your desktop into 3 so you can maximize to each screen. It's not as good as actual support as there are slight edges, but I don't mind it on my 24" monitors, I doubt you will mind it on your 30's. That way you never have to switch out of surround mode.
Never heard of that program, but I'll keep that in mind. Been doing some more research and they say that in order for HDMI to support 2560x1600, I would need an HDMI 1.4 cable. The cards support it, but I don't know if the monitor supports it. I went ahead and purchased the cable from ebay for $1.95 so I guess that should give me the answer I need.
You can only run 2 monitors while sli is enabled unless in surround. Also, you can't plug the 3rd monitor into the hdmi, as there are only 2 clock generators on the card, one per monitor. You would require a DP port on the 580 to run 3 monitors off one card, as DP doesn't need a clock generator.
To run 3 monitors without surround, you must disable sli.
Matrox Powerdesk is actually a pretty good alternative, I'd recommend trying it out and just leaving your monitor set to surround. It was software designed for the matrox triplehead, which was more aimed toward worker productivity than gaming. You can maximize in each screen with it, and set a swap screen button for windows, just there is a little edge.
Considering Nvidia hasn't added such a simple addition to surround drivers makes me think they don't want to tread on their workstation cards ground.
