Anyone have experience with this KVM?
I have it hooked to a vx922 and 2 machines. 1 with radeon 9800 pro and 2nd with radeon HD4850.
On the 1st machine I have win xp installed. When I turn it on I see the bios screen and then the windows XP loading screen, then I get no signal until the Logon screen. After entering the password to log in I get no signal again.
On the 2nd machine I did a fresh install of windows vista buisness 32bit while it was connected to the KVM. It all worked well include the installation of drivers with a few reboots. After that I started updating the windows, after updates reboot I see the bios loading screen and when vista loads screen goes to no signal.
I havn't had the chance to check it again since I installed SP1 for vista, I will hopefully do it later tonight.
Anyone have encountered such Issues or have any idea for cause + solution?
I am running both machines with 1280x1024 resolution and 60 refresh rate.
Thanks in advance
Thanks in advance
