Travelling with PC: the HSF
medium
any heatsink worth it's copper (or aluminum) will probably weigh outside the AMD recommended weight of about 300g.
i'm going back to college soon, and I'll need to fly with my PC - I've kept the box and everything. how much of an allowance would you give to travelling with a heatsink?
currently, i plan to install a vantec aeroflow 2 before I go, which is about 160grams above the recommended weight. am I going to break this motherboard if I travel? i'll take all the extra steps to make sure they don't toss it around: packing rope to make a handle, and yellow duct tape labeled: "fragile, this side up, break it and and I'll hand butcher you"
well, it can't be too hard to take of the hsf just for the flight.
with airport baggage handlers, it's always better to be safe than sorry...
i could, but i'm being lazy :p and conservative of the 3grams i have of AS5. Just to be safe, I think I will take it off before I travel.
Personally, I wouldn't let them touch my pc because they don't give a shit. If you can do it, try to bring it with you in the cabin.
Remember teh opening scene in Ace Ventura: Pet Detective?
'Sounds Broken'
'Most likely, sounds like it was something nice though'
HAHAHA
Remove it befor your trip and reassemble at your destination, or try carrying it on...
either carry it on, or fedex it and insure the hell out of it.. those baggage tossers are called tossers for a reason.. i cant even image how a hard drive would fare :eek:
Hard drives are actually VERY shockproof. WDs can survive a six-foot drop to concrete, as long as they're not on.
well all i gots to say is they werent 4 years ago.. lol.. i had my pc case sitting on a chair for lack of space anywhere else when i was working on something under the desk.. teh case fell, and i got ALOT of errors on my disk...
this man speaks the truth... harddrives are very shockproof only when they are off though. When it is on it's more vulnerable.. especially while it's performing a read/write operation.
fragile stickers mean 'throw me' i had a guitar with a fragile sticker on it and they threw it into the cargo hold from the ground outside instead of just putting it on the conveyor belt like everything else....
If your really paranoid and they won't let you carry it on, you could do what professional musicians do with their instruments and buy your pc it's own seat. :p
i supposed i could fedex it, but i think that'll be a last resort because I don't want to cough up the cash for that.
thank god for hdd grommets, i'll simply remove my hsf, and possibly my powersupply. everything else seems pretty sturdy for the flight. optical drives :eek:
It'd be much easier to remove the Aeroflow2 before you travel. With the way it's designed, you don't need any tools to mount it. The hardest thing will be applying the AS5 correctly, and that's not even hard.
The best option is of course to remove it.
However if you really want to keep it on, I think the best solution would be to fill the case tightly with bags of air, such that they would put light pressure on everything they touch. This isn't really that practical though.
If you have control over how it will be placed, have it placed on it's side so that the CPU HSF sticks up. Don't worry about the harddrive, like they say, it has pretty good shock protection. Using this method, I've carried my PC back and forth in my car plenty of times and nothing ever went wrong from that, and I KNOW my HSF is no light thing since it's all copper and a bit larger than technically necessary. You really shouldn't have to worry about anything. As for the optical drives, yes they have moving parts, but, they are made to handle being mounted sideways even, so they can handle being shaken around a good deal with no damage (though lots of read errors if you actually had a CD in obviously.) I never removed a thing before carrying it off.
