Transporting & Storing Gaming Rig
capreppy
[H]ard|DCer of the Month - April 2009
Ok.
I will have 3 to 4 nights a week away from home and I wanted something there to use for gaming. I had thought about an XBox 360, but I need more utility. In addition, my laptop for work really doesn't work fast enough (I run Oracle 9i, Informatica, Actuate, and other software). So I decided to build. I've got my rig decided on and will be building after the July 22nd Intel price cuts.
This is my situation:
I am a software application consultant. I will be in Chicago, IL for the next 24 months. I fly up on Monday mornings (sometimes Sunday nights) and return home on Thursday afternoons. I will be staying at a hotel that I can store (with assurance that only I can get to it) my rig and accessories.
I will be transporting this rig and monitor to my home away from home. I will probably ship there and then ship back home at the end of the engagement. I would take on the plane, but I've flown enough to know that that probaby isn't a good idea. Even with a tag that said fragile, I'm pretty damn sure, it'll get tossed onto the belt by a luggage handler.
While at the hotel, I was thinking of a foot locker (or something similar) well padded with foam padding. The foot locker will need to hold my rig (Antec 900) and monitor (Samsung 245BW) and other miscellaneous accessories. It will probably be shipped in this so I don't have to find one after it's already there.
Dimensions:
Antec 900 - 19.4'' x 8.1" x 18.4" (LxWxH)
Samsung 245BW - 22" x 17.5" x 3 (WxHxD) (Without Stand)
probably 1-2" foam padding below the Antec 900
probably 1-2" foam padding between the Antec 900 and the Samsung 245BW
probably 1-2" foam padding above the Samsung 245BW
So my questions:
I will be installing a Thermalright Ultra-120 Extreme CPU Cooler, should I worry about padding that in some fashion so that it doesn't move around in transport? or while being stored?
Is the idea of a foot locker (or similar) a good idea?
Has anyone had a similar situation? What did you do?
BTW, I did look at Pelican Cases. The Pelican 370 Cube Case works perfectly (I think), but at $400 for the complete solution, not really practical.
uninstall the CPU HSF and graphics card. Package those seperately. Sorry, thats all the advice I have for your situation, hehe. I wonder if you can bring it as a carry on...
My wife thinks it's a bad idea, but I know when I was in Denver, CO for 6 months last year, I was about ready to KILL myself with boredom. Part of the problem with having just the corporate laptop is the tendency to work and work and work!!!
I think I may have found a case that will handle this. The Pelican 1640 will take the Monitor & Rig and accessories. The Monitor Stand is the only thing that is awkward and doesn't really fit inside the case. The case can survive just about anything and comes with foam padding that can be setup to accomodate any size item. There is a discount retailer that has them for $200 including the foam padding.
The only real accessories I will have is the keyboard, headset (not going to bring a full speaker system as that adds even more space requirements), and cables (which can sit on top of everything else).
Definitely take into consideration removing the HSF & GPU. I may even consider the HDDs. The HSF & GPU are easily reinstalled after I get there. The HDDs, as long as I leave the cabling alone, can just be slipped back into place upon arrival. The removal of those few items makes it less "fragile" and would weigh less. In addition, I'm not worried about the HDDs being bounced around.
I had thought about putting the rig in my carryon, but that leaves very little room for clothing for the week ;)
I'm actually looking forward to this gig as I'll have something to entertain myself at nights.
Heh, I'm surprised the wife didnt make you bring her along.
The HDDs can sustain a lot of shock when not operating, so no real need to worry about them, unless the HDD cage is rather weak.
im kinda confused....do you need this like lan party luggable as in mid tower with handles and aluminum? or do you need it as a reliable stow away for gaming on your visits?
Im also worried about the heatsink for the cpu....those big ones get pretty heavy, and if your gonna move it around alot it could damage your mobo....taking them off is a real pain but if you are gonna lug it alot youd better take it off
hdd and other things are less of a worry...hdd's park the heads so as long as its tightly secured to your case things should be fine
if you use pelican cases or any other water tight case make sure to throw some silica gel packs in there. water wont be able to get in and that mean any moister inside wont be able to get out.
I stay during the week only: Monday (sometimes Sunday) thru Thursday. I would only be using the box during the nights I am in Chicago. The computer would go back into the carrying case on Thursday mornings and checked into the hotel office until my return the following Monday.
When I was in Denver, I did the same type of travel. First flight out on Monday morning and return on last flight out on Thursday evening. I did fly my wife out once a month and I would stay the weekend and we'd see CO together. I will probably be doing the same thing during this engagement.
Getting from my home to IL would be my biggest concern. Heatsink and GPU would probably come out during the transport. Once onsite in IL, I would probably leave everything in week to week. I know that the box will be heavy as all get out, but it shouldn't be too hard to get the rig into the box. The foam padding will be basically custom fit to surround the rig. The LCD monitor would go on top with 2" of padding between the two. It would only have to go from my hotel room to the ground floor inside the nice and secure Pelican Box. I would be putting a padlock on it during the weekends that it would stay in the hotel.
I will definitely consider the silica gel packs. I hadn't thought of that.
I am installing a Thermalright Ultra-120 Extreme. It does have the bracket for the installation to the MoBo. It'll be removed during the transport to IL, but left in week to week. I would not expect it to be jostled around at all. Basically into and out of the Pelican Case on Monday & Thursdays.
After continued research, this seams to be the most elegant solution. The box is very heavy (40 lbs without the foam), but it is very secure and will take a beating without affecting the contents.
