I'm wanting to transcode my entire library. At first, I'll keep my old files available just in case my settings were too aggressive. I know the recommended approach is to rip directly to what you want instead of transcoding and enduring the additional loss.
In my collection, most of my older songs are 128kbps cbr. Progressing to 160, 192, 256, 320, as well as lots of vbr.
I'd like to use vbr, and cut down the footprint on my computer, as well as on my ipod (I currently do transcode beyond a certain bitrate for my ipod, but am looking to have everything slimmed down).
I did a lot of reading and found what "optimal" values would be to use, but figure I'd ask for a more personal opinion if one can be given.
Personally, I used to think 128kbps was all I'd ever need. Nowadays, I can tell 128cbr vs 160cbr for some songs. For some others, 128 is still good enough. But that said, I'm pretty much completely content with 160kbps cbr, so I'd like to work from there.
I understand that sometimes, I'd possibly want more than 160kbps for parts of certain songs (wouldn't be able to tell currently since many of my songs are >160). So that said, I'm imagining that setting V to 3 should be more than enough for me, and still allow it to drop low enough when not as needed? I did some tests at 2, and it pretty much hugged the max bitrate I chose. 3 seemed to go much more sharply lower.
And what about near silence parts? From the guides I've seen, the min bitrate is still set to be quite high (96 is usually the lowest I've seen recommended). Is there a way to allow silent parts to go down to say 32kbps (or even lower if it's still acceptable) or something like that without harm to where bitrate is needed? I assume this ties in closely with what I set V to?
I've been using winamp to do the transcodings using lame, but was wondering if there's something better to use. Also, if it could support multiple threads, or at least run simultaneous transcodes on the different cores, that'd be great (winamp only does one thread). Free would be nice too, and batch transcoding is a must.
So here's what I'm thinking:
lame vbr 32-192 V3
is there a problem with this?
Also, one thing I've found with winamp is that even if the source is only 128 or something low, after the transcode, it'd almost certainly be higher in bitrate than the original, and thus defeating the purpose. Is there a way to make it follow a different ruleset (maybe have it cap max bitrate at whatever the max/cbr of the song is?)
While I will be keeping the original mp3's for a while until I'm sure I'm satisfied with the results, I'd still like to get some advice and do it a way that isn't too horrible, since it will take quite a long time, even with two threads and 3.6ghz c2d.
Thanks!
edit: currently, I have songs going to the ipod transcoded to 96-224 v2, and am able to fit about 40% of my total collection. Albeit it's all the songs that I want on the ipod at the moment, my ipod is sitting at 28gb used (30gb ipod), so I'll be running into trouble real soon in the future. I'm sure 96-192 v3 would be totally acceptable and would win me over a lot more space, but like said, I'd rather do a main transcode on my pc and have everything the way I want instead of having to be constantly retranscoding to find what works.
edit2: also I've been using joint stereo. nothing wrong with that right? I understand it should be able to save some space without much sacrifice
edit3: while I'm at it, if a program could also normalize it as well. might as well do that as well so I don't have to be constantly changing the volume when on shuffle
lame vbr 32-192 V3
Thanks!
