So I have a FireMV 2250 PCIe 1x card that I was going to toss into my home server build to give me a low power video output, but then I thought I could just as easy put in a card to fold on. This is a PCIe 1x card, so it isn't the typical video card and is good for the mini ITX boards that only come with the 1x slot to give you two outputs. I received it as a part of a bundle, but I have verified that it works without issues. Will included both full height and low profile brackets, 2x VGA output and 2x DVI output adapter cables (requires adapter cable, cannot just insert DVI cable straight into card. Note that the card linked just has a straight adapter, where as the card I'm offering only has a dual output adapter cable. I'm not really sure what this is really worth, but just send me any offers you may have.
Heat: hiodie
Heat: hiodie
