Hey folks.
I am at my whit's end here. I recently started encountering a problem with my router limited bandwidth as if there was QOS enabled somewhere. It happens wired and wireless as of a couple months ago. Wired directly to the modem I get 940mbps/42mbps. Wired to the router I get 940/23mbps.
All settings related to parental control, QOS, gaming are disabled. Rolled back firmware to one I know worked fine to no avail. I can't pinpoint any changes that would have prompted this.
I run a Plex server for my family so every bit of upload I can scrape is important.
Here is the model. Note it is the AX6600 model, not the AX10000.
https://www.amazon.com/TP-Link-WiFi-6-Gaming-Router/dp/B08TGKX9MT?th=1
I have seen similar people encountering this issue, but couldn't track down a root cause.
Any suggestions?
Any suggestions?
