Okay, I have just recieved my 2001FP, and it's essentially PERFECT.
I mean, only 1 dead subpixel that you have to be 3 inches away to see, and even then you have to strain for it.....
SO, the pixels are fine.
But, my issue is the BACKLIGHTING.
I'm a total perfectionist....i mean, extreme perfectionist.....and it has a VERY small "light bleed through" in the upper right corner. About 3 inches of the screen on the top border have the problem.
Should I send it back? Am I being WAAAAY to picky? You can only see it when it's a black background (DVD's) (no wall paper). If you have a window open the windows title bar blocks any bleed through you'd see.
What would you do? Remember, you just dropped $865 on it
Convince either way of your point, please
