VenomousDesigns
- Jan 4, 2009
Good evening,
I come to you with a small delimma on my hands, I am faced at buying a new PC Case for my system - This system was the first time I've built one, and its gone quite well up until this point, not to go into details but the case I'm currently using now has NO fans (3 yearold hand me down) and I decided instead of spending $80 (Australian) on new fans I would invest in a new case altogether.
Although exciting whenever it comes to purchasing new PC parts, the doom and gloom soon sets in - Which is the best, should I get this, should I get that etc (The same philosophy can be applied to whenever we spend money
BUT to the point - I BELIEVE I've narrowed it down to two cases; the Coolermaster HAF 932 or the ATCS 840. Having read EVERY review to date on both machines (yes, over 8 hours of solid reading across the board no jokes) I am back where I began, as one review put:
Currently my computer specs are:
CPU: E8400 with Noctua NH-U12P Heatsink Cooler
Mobo: P5Q Pro
GPU: 8800GTX - Soon to be GTX285/295
PSU: Corsair HX620w
Sound: Audigy 2 ZS
HDD: 1x 1TB, 1x 300GB Samsung 7200rpm 32mb Cache HDD
I come to you with my hands open - if one of you were currently in the market for a new Gaming/Performance case which would you choose? I LOVE the design/exterior of the HAF 932 but with no dust filters it worries me, on the OTHER hand the ATCS 840 has higher temperatures etc.
Please refer to a recent Coolermaster Sniper review that shows graphs comparing a number of up-to-date cases [Basically shows the HAF 932 with better temperature ALL round]:
http://www.bit-tech.net/hardware/cases/2009/01/12/cooler-master-storm-sniper-review/4
Also note worthy is another comment from another review concerning the ATCS 840:
Thanks,
VD
Unfortunately, its like comparing to fine automobiles and trying to prove one is better than the other. On the one hand you have the equivalent of an American Muscle car and on the other hand you have a Jaguar E-Type. Both are great in their own way and both have their pros and cons.
Mobo: P5Q Pro
PSU: Corsair HX620w
Sound: Audigy 2 ZS
We think the difference in performance between our top performers and the ATCS 840 has likely been caused by the sheer size of the case. All our other top performing cases, the HAF 932 especially, tightly surround the CPU and GPU with exhaust or intake fans, drawing heat directly off of, or blowing cool air directly onto the CPU cooler and our test set ups passive GPU heatsink.
The problem is that the ATCS 840 has become a victim of its size; the primary 230mm cooling fans are placed comparatively far away from the core hardware and so have limited effect in directing airflow off of or on to the sources of heat.
Thanks,
VD
