So I need a touchscreen monitor for a jukebox/digital picture frame project I am redoing.
I previously had this setup and the 27" TV I had doing this croaked. I had used a 3M overlay to make this all work and it did ok but wasn't super responsive.
Now that I need to change this out and get it going again I am looking around (thanks to Windows 8 prompting more TS monitors being produced) at a dedicated touchscreen monitor for this job.
Some minor requirements
Touch must work well as this is used for JRiver Media jukebox functionality and it needs to be responsive but not overly sensitive
Screen must be able to hang on the wall.
2 HDMI inputs would be nice (but at least 1 HDMI and 1 DVI required as I do hook DTV to the other input for special events to play on this screen (like the Super Bowl))
Built in speakers would also be nice but not 100% necessary
So what works best in the 23-27" size range?
I also not against an All-in-One unit that I can hang on the wall as I will most likely use a separate Intel NUC to run this project.
Thanks in advance
Greg
Thanks in advance
Greg
