Touching PSU and case good for grounding?
3far4shot
I don't have a Anti static wrist strap. So would touching the psu and case be good enough?
ya, i usually to a doorknob (if its metal) and the case.
make sure to take ur socks off also
Touching the PSU should be more than enough. If you're not in a carpeted area and are not wearing socks, you don't even need to worry about grounding yourself.
All this is predicated on the fact that the PC is still plugged in and it's plugged in to a properly grounded power system in the first place.
Just touching a case ain't gonna route the electricity anyplace if you're "charged" up - the machine has to be plugged in but not necessarily powered up, and that ground circuit has to be grounded.
Then i can uplug it?
