Totally confused.....
So I have a GeForce 8800GTS 640MB card and Oblivion. According to the Tweakguide for it, "Finally, you also can't enable HDR and Antialiasing at the same time unless you have an ATI X1000 series card or newer and the latest Catalyst drivers, or a GeForce 8800 series or newer."
So uhh....wtf? Everytime I try to adjust the setting from Bloom to HDR it says "HDR and Antialiasing cannot be enabled at the same time. Disable antialiasing."
Am I missing something here?:confused:
in the game, enable only HDR, leave AA turned off. then in the driver control panel, select your desired level of AA.
