I've done a search!!
I can't find anything that talks about total power consumption of a PC...
What's the best way to meter how much power my PC is using? I've heard of the Kill-a-Watt, but supposedly it's not very accurate.
I'd like to know how to save some energy with my PC (without turning it off). I know that putting the monitor in standby ASAP is good, but are there other things I can throttle back that will help?
We should really have a sticky thread on this matter, being greener should be a part of who we are, because as what I call "Power Users", a lot of us run computers that draw a ton of energy. If we could all find a way to save 50watts/hr, that would add up to a lot of electricity.
I'm open for suggestions.
The one thing I've done is that I've told my PC to hibernate after 5 minutes of inactivity...is there something else I can do while I'm using my PC? I don't need the maximum power of my computer to surf the web for example, but for gaming I do. Is there a way to either a-control this manually, or b- a piece of software that will do if for me automatically?
Thanks!
Thanks!
