I just switched, i will never go back!! uTorrent RAWCKS!!darktiger said:I use to us azureus, but now uTorrent. It is just as fast, but less resource hungry....
Retardo said:ok i just switched to utorrent. need a little help and didnt want to make a new thread. i came from bittornado and it had options to use ports from XXXX-XXXX now in utorrent i only see one option called 'port used for incoming connections' and thats XXXX well i have a router firewall and i can foward ports XXXX-XXXX. so what should i fowrad my ports too if say the port used for incoming connections is 1234? 1234 - ???? is there a way i can tell that im not behind a firewall?
and is there anything else i can do to make it faster?
I just use the same port, port forward that one port and never looked back.Retardo said:anybody?
HighwayAssassins said:I just use the same port, port forward that one port and never looked back.
Why do you need to use a group of ports? One port should just work fine...
