Originally posted by Jrmicon
Not to be a dick but I am just curious as to why people buy a tornado and then 5v or 7v it. If you are going to do that why not just buy a non tornado fan or do you just want to say "I have a tornado?"
Originally posted by Aris
i always used 92mm Panaflo L1A or papst fans for my cpu heatsinks. i never keep stock fans. I dont think ive ever seen a stock fan in anything that ive just accepted and left it be.
some fans wont start spinning at 5volts. so just check to make sure yours does. also i wouldnt suggest dropping to 5volts on an 80mm fan. your airflow will suffer too much. with a 92mm it shouldnt be such a big deal.
7volts works in almost any situation though. ive never seen a fan not start up at that, and its noticably more quiet. also i wouldnt ever 7volt any fan thats smaller than 80mm. just cause the smaller fans barely push any air to begin with. cutting them down in speed makes it basically nill. you might as well just put a good passive sink on it rather than 7volting a fan smaller than 80mm on a crappy small heatsink.
Originally posted by arDAWG
I used to run the Sunon version of the Tornado w/ an AX-7 and the noise convinced me to move to water cooling.
