D
Deleted member 88227
Guest
Get a better GPU so your CPU isn't doing most of the work. You'll see a much, much better improvement with a new GPU than you would with any CPU.
you should know that GPU fans usually die after 1-2 years of heavy 24/7 use
Um yeah, no.
CLC's have a much higher failure rate.
*quote:
However, on a CLC, you have all of the parts in a water cooled system that can fail, only often lower quality.
- Fans (like in an air cooled tower)
- Pump
- Galvanic corrosion over time on the parts
- Leaks are a concern too
The Fury X CLC had a plethora of pump issues. It was thoroughly discussed and documented.
EDIT: Don't get me wrong, a CLC cooler on a heavily overclocked CPU makes a lot of sense. Other than that, the risks far outweigh the benefits IMO.
Yes, i understand your concerns, especially when there is a leak, it can kill your whole system i suppose. And reading through the coolermaster warranty, they made damn sure that this is not covered by them
In spite of your justified concerns, personally i believe that the benefits outweight the risks, if you do not cheap out and get a liquid cooling solution with at least 5 years of warranty.
If we're still talking about Vega, I'd look into an HG10 type cooling solution instead of going with AMD's stock CLC. (pretty damn sure their doing air-cooling this round though. IF leaked expo pics are anything to go by)
