Torn between 3 PSU choices
MissingGhost
Hi,
I need a new power supply for a rig that I'm upgrading. The problem is that I found 3 PSUs that are very similar and I don't know which one I should take.
Seasonic S12-500HT 500W $119.60 CAN
Enermax Liberty ELT500AWT 500W $132.25 CAN
Silverstone Element ST50EF-PLUS 500W $103.53 CAN
The Silverstone unit seems a little cheaper...
The Seasonic and Silverstone are at the price of the only store I know that sells them in Canada (NCIX.com)
Which one would you get?
http://www.ncix.com/products/index.php?sku=20650&vpn=HP2-6500P(G1)&manufacture=Zippy%20Technology
Of your 3 choices though, the seasonic would be great.
Silverstone. The Enhance unit it's based off of is a solid PSU.
Zippy is loud and inefficient.... both noise and efficiency are important to me.
