Top N routers out there.
Malakei
Hey guys im still on a old Linksys wrt54G router and its time for an upgrade. Any perfmance difference in gaming will help out alot. I find i get alot of choke/loss in gaming servers sometimes and i know alot of that is the server but its happiening so frequently now that i think my router is just about toast too. So, that being said looking for top recommended routers for gaming. I currently use Ethernet cable to my router so it would be preferred to have a wired option as well. But im thinking wireless N is the way to futureproof myself. Draft or whatever runs best. Print server option would be great but depends on the price tag it comes with. Not looking to spend 200 bux on a router if i can help it so try and keep it as reasonably under 150 as popssible or even lower if a good one can be had for that.
Cheers
actually print server is low on the priority list so either scratch that or just simply make it a plus but i dont need it.
DIR-655 or DGL-4500. Both are outstanding gaming platforms - both offer QoS but the DGL-4500 has additional pre-defined and game-specific (GameFuel) rules for almost double the price.
