top 3 computer certifications
SiDiuS
not quite sure where to post this so I'll just post it here. Whats the top three computer certifications that have most job opportunity In your opinions?
-SiDiuS
Deal Svengali
Oracle, Cisco, MCSE, but it depends on what you want to do, the MCSE is expensive 8 tests if I remember right. The 1st Cisco cert is only one test.
logo29a
It all depends on your field or the field in which you want to be. If you're into networking then the MCSE and CCNA are good starts. Neither are quite as valuable as they once used to be. The CCNA will regain some of its value now that the newer, harder exams our out.
It might help to go to some of the job opportunity websites and see what employers are wanting. Then find out which exam's certification holders are in short supply.
plot
i agree with Oracle and Cisco. not sure of what a third would be...
djnes
You will also find that given the current economic climate, certificates are worth less and less. Degrees and experience are what really matters.
