Tools to open hard drives
Techx
Does anyone know the types or names of tools needed to open most hard drives. I have many dead hd's from my job and want to open them up but most have screws that are more like a star shape, not hex though. I've never seen a tool with a star shaped bit, does anyone know where I can get them?
Thanks
those are quite common for electronics. You should be able to get them at any local hardware store or electronic store. The insides of a hard drive is pretty cool. Keep the magnents inside, they are good to hold your extra screws that you get when you buy computer hardware.
thanks, appreciate it.. now if i can only think of some cool mod to use all those platters hehe... oh i got it ill hang em from my rear view mirror :D :p
DONT DO THAT! i did that before and omg almost died. That thing will blind you! my friend made a clock out of it. pretty cool.
I just use the little star tipped bits for my screw driver and sometimes the Torx ones. :)
you could thread a platinum chain through one and wear it around your neck. When someone asks wtf it is, just be like "This is 5g(B), biotch!" and slap their hoe face with it.
i got pulled over for doing exactly that, i guess i was blinding the cop behind me. all i got was a warning for it
Woops, good luck on what you do with the opened hard drive, and keep us up to date :cool:
