Took the plunge and ordered a 2001fp
MisterDNA
Holy hell this thing is sweet! And it got here quick too.
The stuff you all really care about: No dead pixels, no backlight leakage and in my case no screen door effect (supposedly because I wear contacts, based on another thread). And, for some reason, no ghosting. I play Serious Sam with no trouble and my display test software doesn't ghost any more than my Mitsu CRT did. Maybe it's just my eyes?
Me = wants another one :p
Original message
It came to $769.20 total after the 20% discount and the $30 off code. Pretty good by itself but even better because Utah means no sales tax with Dell.
Going from an 85lb Mitsubishi 21" to this flat panel at almost 1/4 of the weight and depth will be nice. And 1600x1200x24bit over DVI beats fuzzvision any day.
It's a good CAD display, I'm sure. Not sure what to expect when gaming. But I will find out in a few days.
MisterDNA said:
Aw damn. Found a dead red. Took forever to find.
When i had a 2001fp for a week i found a bunch of dead pixels. The red ones were considerbly less annoying than the bright green ones glaring at you. Actually i never noticed the red ones until i got really close to look for dead pixels. Mine had 6 or more so i sent it back.
I dont think i would go through the hassle of sending it back for one red pixel, for a green one i would though.
What are you planning on doing?
I have one at work as so does a coworker so we both ordered them for home as well. The ones we have at work are refurbs and work well except I cannot get mine to run with the DVI, even trying the fix that Dell came up with for Geforce cards, mine being an Asus 5900XT.
The first monitor that I received for my home PC had really bad backlight leakage so I received a replacement and this one does too. It is not as bad as the first one, but not acceptable to keep and it also has a stuck pixel almost in the middle of the screen. Both have worked with DVI with my Radeon 9600XT right out of the box though.
I called Dell for my third replacement today and hope that this one works. If not, I'm going to get a refund and probably spend a bit more and try the HP L2335.
Kirk
Keeping it. Especially since I rubbed it back to life. Perfect panel now. I prefer dead reds because even with a dead red and a white background, you're still looking at a bright color.
yes and a dead red on a black back ground is much less visible than a green.
nice work getting that pixel back to life.
How do you get a pixel back to life? I thought once they were dead, there was nothing you could do. :confused:
Sometimes if you lightly press or rub on the display, you'll connect the film inside that wasn't connecting. Rarely works. I managed to do it on my laptop and it happened to work on the FP as well.
but even if it hadn't, one circuit out of 5,700,000 not working is damn good.
Leme see, a very tiny guy with very tiny hands....and an itty bitty soldering iron.....each monitor gets 5700000 connections.....ah..never mind ;)
Love my new 2100FP too, huge value in the lcd business. No dead pixels here and after a bit of calibration very black blacks.
Enjoy
BillR
