hotcrandel
- Feb 26, 2010
I've got some older but still use able servers on the shelf at work I want to make available for ESXi capacity.
I've been happy with some of my latest builds but these last few servers I have aren't necessarily ideal for all-in-one due to various factors.
This thread pertains to disk configuration; read on for background.
I've got four different 1u supermicro server;
(2) dual core2 quad xeons, 16GB ECCram, redundant PS, quad-hot-swap ultra 320 disks
(2) single core2duo xeon (3040 1.86ghz), 8GB ECC, dual hot-swap SATA
Was thinking about making the 2-bay SATA servers into data store with either a pair of 1TB velociraptor, or 2-3TB 7200RPM, then maybe ZIL or zARC sata disk fastened in a PCI slot.
Planning on running 16-32GB of low usage VM's per server
Asking for opinions between
zfs/R1 1TB velociraptors without ZIL,
vs
2/3/4TB 7200RPM disks with ZIL, at about the same upgrade cost ($500?) or so per server.
Also; Am I making a mistake trying to do ZFS on a 1.86ghz dual core with only 8GB RAM?
I've got a server with 6x2TB disks that i'm pretty underwhelmed with the freeNAS performance. no ZIL, 16GB RAM, etc. iSCSI might also be the issue as well. Lots of latency reported by ESXi, and its felt pretty readily in the guests.
Edit; not sure if ICH7R supports 4TB disks. You would like to think it could..
vs
