Too much weight or pressure on cpu?
I'm having trouble getting my gigabyte dsr2 matx board to fire up. I have reseated everything at least 3 times and it's still a no go. I have switched my ram (4gb crucial) in many different configurations and it's still a no go. The PSU won't even light up. ANyway, I was wondering if weight and pressure might have damaged my chip (e6850). I installed a zalman cnps8700 on it and the thing has a very tight fit. It also has me spooked because once you clamp it down there's quite a bit of pressure on the chip itself. Could this be a contributing factor to my problem??
thanks,
EF
If the PSU fan doesn't even spin when you short the green and black cables while plugged in and turned on... then its more or less dead.
Heatsinks use a lot of pressure to maintain good contact with the IHS. Cut my fingers several times installing that damned XP120...
Make sure the pins are not bent, or twisted to one side
pins? of what? the LGA775 CPU? :p
/*------------- </cut n paste> -------------*/
If you have both the 20/24 pin main ATX connector plugged in, AND the 4-Pin ATX12V P4 CPU connector plugged in, then the board should boot fine. One thing you could try is clearing the CMOS.
You could test the PSU. Jump start it (on the main atx connector, short the green wire with any black wire, using a paperclip), and see if it stays on. If not, then its a faulty PSU. If it works then proceed.
Setup everything outside of the case, with the mobo on top of its cardboard box. Plug in only the essentials:
- PSU (namely: main 20/24-pin ATX connector and 4-pin ATX12V P4 CPU Connector)
- CPU w/ HSF
- Single stick of ram
- Videocard if there is no onboard video
- Monitor
- Keyboard
- System speaker/buzzer
* Use a screwdriver if your board doesnt have an onboard power switch. Jump the two power switch leads to turn the power on.
If it won't post, try different RAM slots. If it still won't post, pull out the ram (so no ram in the system) and listen for error beeps. If none, pull the vidcard and listen for error beeps. If none, re-seat the CPU/HSF and try again. Report back with results if you're still having issues.
thanks for the help guys. I think it may be my power supply. I jumped the green and black wires on the PSU and the fan comes on for 5 seconds, then stops for another five and then comes back on. I hooked some elwire up to get more of a visual perspective (as if the PSU fan didn't tell enough) and the elwire comes on and goes off with each fire up the fan. Shame, I had high hopes for this Enermax that I purchase as "new" on Ebay and there's no way to return it. I will try to RMA it but until then I am going to purchase a new PSU at bestbuy or office depot. That way, if it's busted I can return it pronto.
I don't think BB nor OD have good choices for PSUs. I think from those two places, your best bet would be an Antec Earthwatts, Truepower TRIO, or NeoHE PSU. Some Ultra PSUs aren't bad, either.
