Too much voltage?!
DaLurker
So right now I'm priming at 2.85ghz with 1.715 Volts. Temps are fine (probably 40-45 under load). MY coolings in my sig.
Do I have too many volts running through my CPU?
temps: ok
i'd say you're fine! if i could get 1.7 volts i'd probably run it :D
what's your processor though? i'm sure there's some "official document" that says x volts are too much. google that for your specific processor.
edit: ah processor in sig... i would run 1.7 whatever volts. some wouldn't though
