Long story short:
Have 8 400GB drives and want to do a RAID 5 array with those.
RAID'ed them and left 1 hot spare, for a total of 2.8TB.
I went to install windows and apparently the most it detects is 2.0TB since that seems to be the max for an MBR.
The system is going to be used as a security system storage machine that is going to be constantly using the hard drive.
Here is my question/concern.
The only other alternative I saw to this was the following 3:
1. Make a full RAID 5 partition with all 8 drives and use 2 as hot spare, leaving me with 2.54TB of storage. Out of those make a primary partition that would use those .54TB=550-600GB's and then make the secondary partition a full 2 TB in order to save/record everything to that.
Now the thing with this setup, is that I heard that since the hard drives will be under constant writting, that its not really recommended to have 1 drive(RAID would make it seem as one drive) with multiple partitions if it needs to be constantly written to.
Other method would be:
2. Make 2 RAID arrays's.
FIrst one would be a RAID 1 array with 2 of the 400GB's. Install windows on that RAID array. Or I can replace the 400's for 2 36GB raptors, since I really dont need that much storage space on the windows partition.
Second would be a RAID 5 array with the other 6 disks, and 1 hot spare, and 5 working for a total of 2TB, and use it as storage.
Any other ideas? LOL I never knew having TOO much storage would be such a problem.
