My machine:
Asus A8N-SLI
AMD x2 4400+
EVGA 8800 GTS 640MB
Antec Earthwatts 500w PSU
2 optical drives (1x DVD+R/DVD-R 1x CD-RW/DVD)
3 SATA Hard drives
1 floppy (yea I know, still comes in handy here and there)
My problem:
Random shut downs. Mainly when I fire up World of Warcraft. It's not limited to this though. It occaisionally occurs at other times too. Was watching a video last time it happened when I wasn't gaming.
What I've tried so far:
I had Vista Ultimate running on this when it started getting bad. I kept getting a BSOD for nvstor.sys when I'd try to play WoW. Everything I found from searching "nvstor.sys" pointed to issues NVidia's SATA driver in Vista. I'd been wanting to see if I could up my FPS in XP (it didn't) so I reformatted and installed XP SP2. Still would get shutdowns but no longer got a BSOD.
I replaced the hard drive that contained my system partition and the partition WoW was installed on. No luck. I was finally able to get XP to throw a BSOD though. Machine_Check_Exception 0x0000009C (0x000000004 0x8054D5F0 0xb2000000 0x00070F0F) is what I get.
From what I've found from searching so far it's one of the following: Power issue, heat issue, hardware issue with PSU, Mobo, CPU, or any other part you can think of.
I ran the NTune software and turned on logging and didn't find any issues with tempature at the time of my crashes. I've ordered a CoolerMaster 750 PSU (http://www.newegg.com/Product/Product.asp?Item=N82E16817171024) hoping it's a power issue. Is there an easy way to see if I'm putting too much load on the PSU or it's going bad?
EDIT: I've also tried booting using different SATA controllers.
EDIT #2: Forgot to mention the memtest. Ran for about 12 hours with 17 passes and no errors.
Asus A8N-SLI
AMD x2 4400+
EVGA 8800 GTS 640MB
3 SATA Hard drives
My problem:
