DangerIsGo
- Apr 16, 2005
So I have some h264 mkv 1080p files that I'd like to play on my new Asus 780G mobo, the M3A78-EMH HDMI. Pairing this with a AMD Athlon 64 LE-1600 2.2GHz AM2 45W CPU and 2 GB G.Skill DDR2 1066 (running at DDR2-800), video playback in VLC is maxing out my CPU, to the point where VLC will freeze when I start the file. Other times, it will play about 2-3 seconds of it, then just hang. This is with the latest version of VLC. Next I tried using FFDShow to decode the video and DTS passthrough to my receiver (for home theater) option in FFDShow for the audio. Again, The video is playable, but choppy and laggy where the event would happen in audio and a few seconds later, you would see it. Next, I disabled h264 decoding in FFDShow and chose CoreAVC to decode the video. Pretty much the same thing that happened when FFDShow was doing the video decoding (audio is still passthrough to receiver). A little less laggy, but my CPU is still completely maxed with either FFDShow or CoreAVC. The audio is fine, wonderful in fact. Crisp and clean just the way it should be. Im using the HDMI (with audio) from the board to the receiver. I know my CPU should not be maxed at all while doing this playback. Yet it is. Anyone know what I am doing wrong? Why would my CPU be maxed? Any things I can try? Thanks.
