Needed more space for harddrives. All my options seemed pretty expensive for barely more space. Right now I've got 16 drives. To get 20 drives would cost a few hundered.. not worth it.
I might just have to swap to larger size drives... which would cost money as well, but imo better spent than expensive new case.
... ANYWAYS, in an effort to save even MORE money I'm trying to build something that will let me add more drives but not cost me anything.
So I went and got some random, damaged, case at work. Drilled out all the internals to make space for harddrives. My plan, right now, is to have two stacks/towers of drives holding 10-11 harddrives each, up to 22 total.
Because of spacing it will be too difficult to use screws to hold in the drives so I"m thinking of using 'stretchrite round elastic cord' to suspend all the drives. This will be cheap (20 yards cost me $3.50), easy to do (just like lacing up shoes), easy to install drives (just slide them in between strands), and cut down on vibration.
Here is current progress that I did mostly today:
The drives will be held up by those bronze colored shelving things. Tomorrow I'll work on how to effectivly mount the entire structure to the chassis and how to keep them spaced out correctly with the weight of the drives and force of the rubberbands.
If I was just to use the premade screwholes in those shelving rails and was to screw drives to them, I coudl fit 11 drives with 1/2" between each drive. I'm not sure how efficient my rubberband idea will be, I'm hoping for 11 drives still.
Later on I'll need to work on any structure support problems because of drilling out all the internals of the case. RIght now its sorta flimsy but I do not have either side panel on. Worst case this shouldn't be that big a deal.
And hopefully in the end I'll have a case holding maybe 22 drives that cost me <$15.
