Too many fans on single PSU connection?
aquemini
Right now I have 2 Antec tri-cools and 2 low speed Yate Loons hooked up to the same power connection on my Corsair 620HX. That's fine right?
You could probably wire enough fans for liftoff before you'd overload the supply line. 4 is nothing. Don't worry :)
Is that on the "fan-only" line or on a regular power line? My 520HX has a fan-only line (IIRC - maybe it's the Antec in the other computer...) and that has a different limit. Regular should be fine, fan-only might be more limited. Check that the total amp (or watt) draw from the fans is less than the line's capacity.
