Too Many Choices - Help me Pick!
minni14
Hello everyone,
I am a noobie to the forum and I have been looking for a few days here. I am trying to build a home lab, but I am running into some indecisiveness. There are way to many directions to go!
Here is what I want to do:
2 low use server 2008 instances, low processer and can sit at 2gb each in ram.
2 windows 7 workstatons, also low use.
1 ubuntu LAMP server, low use mostly for dev
1 Windows 8 desktop for learning
The servers will likely run all the time, the workstations will be for testing and not always on
For hardware I am looking to make it an all in one with the storage integrated. I think I need 16GB of ram to cover the overhead of everything. No idea what direction to go with processor. I do not need anything other than the basic free esx 5. I do not need to pass hardware VT-d. I do need 64 bit support and don't need a remote KVM or DRAC.
The Lab is really all just for dev and testing, all the data is throw away, so hard disk integrity is not super important.
I am looking to do this as inexpensive as possible, while still being able to use ESX 5.
I was thinking:
SuperMicro - MBD-X9SCM-F-O
Kingston - KVR1333D3E9SK2/8G (2)
Intel - Xeon E3-1230
Seagate - Momentus XT ST95005620AS (2) (are this RAID-able with the onboard controller? RAID 0)
Intel - EXPI9301CTBLK nic
I am a software guy, I have been away from hardware for so long looking at this undertaking is seriously discouraging me, I would love some Input.
Again, I am just looking for a cheep setup that I can toss a few VMs on to make a small lab environment for study and dev. The cheeper the better, I don't want it falling apart or bursting into flames, but I am fine with desktop class hardware if it makes sense.
Give me some input, what would you guys do?
Thanks for helping a noob. Its good Karma.
How cheap is cheap?
From fleabay: SuperMicro 2x Intel L5320 (quad 1.86Ghz), 16GB RAM, 160GB $215 BIN, or if you want Hot-Swap trays Rackable 2U. Ready to install ESX and go. They're older, hotter and use a bit more juice, but it's complete and available now.
Otherwise, build. The board you've selected may have some ESXi 5.0 compatibility issues with the NICs. There's a board member that custom compiled a driver, but you'll have to manually install it.
cheep to me is 400-600. Just looking for the best bang for the buck. that supermicro one looks like it might work. Where are you finding the compatibility for the board? I googled it like crazy and cant find anything that is a thumbs up or down on it.
I appreciate the help :)
Pretty much have the same set up right now as what you are looking to buy in the first post (I bought different ram (~60 bucks per 8 gig stick, E3-1230v2, no drives and just using onboard NICs). Pretty happy with it and it should do what you need. ~750 including shipping although I could have reduced costs by buying a not as nice case as well as powersupply.
Nate7311 is correct about the NIC issue and it is really pretty easy to manually install it.
If cheap is what you're after, I'm pretty sure this Intel S5000PSL 2U Server would do everything you mentioned, and for cheaper than what you expected.
I realize it's listed with only 8 GB of RAM, but I'm pretty sure you can customize that should you choose to order from that particular website.
How cheap is cheap?
id nuild with new stuff, save $$ on power and heat lol. plus that 1 u would be LOUD
