Too low CPU frequrency
Discussion in 'Overclocking & Cooling' started by patryk0493, Aug 12, 2017 at 7:29 AM.
  1. patryk0493
    patryk0493 n00bie
    6
    Saturday
    Hello,
    I've problem with my old setup. CPU frequency is too low (about 30% above) and is constant. I tried check it on full load, but frequency is always the same (near 2GHz). I made BIOS reset. How to return to full CPU frequency?
    Here are BIOS screens : click
    I hope for any help. Bye.
  2. arestavo
    arestavo [H]ard|Gawd
    1,270
    Mar 25, 2013
    Take a look at your Windows power plan under advanced settings to see if the maximum processor frequency or maximum processor state % is limited.
  3. Araxie
    Araxie [H]ardness Supreme
    5,546
    Feb 11, 2013
    have you checked temps? it could be temp throttling..
  4. patryk0493
    patryk0493 n00bie
    6
    Saturday
    I've check power management settings - is checked for maximum performance. Temps are right to - in max stress I've seen 55 C.
  5. pendragon1
    pendragon1 [H]ardness Supreme
    5,363
    Oct 7, 2000
    disable C1E in the bios see if that helps. if not you could try using a program called "throttle stop" to set the multiplier to 9 instead of 6 to get it running permanently at full speed.
  6. patryk0493
    patryk0493 n00bie
    6
    Saturday
    After disabling C1E, problem still there is. I tried throttlestop but it says that my processor is not supported. Maybe MOBO don't support this processor?
  7. pendragon1
    5,363
    Oct 7, 2000
    bios up to date? if possible...
    what chip and board is it?
  8. ChristianVirtual
    ChristianVirtual [H]ard DCOTM March 2016
    1,167
    Feb 23, 2013
    And is the cooling working ? Thermal paste or fan replacement needed ? Dust In airways ?
  9. patryk0493
    patryk0493 n00bie
    6
    Saturday
    I tried do download latest BIOS, but browser shows error 500 page. Cooling works fine, I've replaced old thermal paste, fan and radiator is clean.
    MOBO: Fujitsu Siemens (ECS) G31-M2
  10. pendragon1
    5,363
    Oct 7, 2000
  11. patryk0493
    patryk0493 n00bie
    6
    Saturday
  12. pendragon1
    5,363
    Oct 7, 2000
  13. patryk0493
    patryk0493 n00bie
    6
    Saturday
  14. pendragon1
    5,363
    Oct 7, 2000
    your board supports that chip out of the box so something else is going on. maybe trying clearing your bios again and make sure the multiplier goes back to 9 instead of 6.
  15. BlueFireIce
    BlueFireIce [H]ardness Supreme
    5,186
    May 29, 2008
    What RAM and speed are you running? Multi should be 9.5 not 9 as shown in the screens. What are you using for loading the CPU? Is the screen of the clock speed while it was under load?
    Have you cleared BIOS? jumper or removing the CMOS battery for a min or two, then booting and setting everything to best default?
    Was this system run with another CPU before?
