Finally broke down and bought an i7 rig. I got a new waterblock (Heatkiller 3.0) to keep things cool. I've got it running stable at 3.31ghz, but it's running too hot and I don't want to push it up any higher. Loaded temps are pushing 80C (using RealTemp), and that ain't right. Water temps are running around 40C, and the fan air off the radiator is noticeably warm. Ambient air is around 72F. It's a fairly small rig with a single-fan radiator, cooling only the CPU. It was more than adequate to cool my old E6400 even at slow fans speeds.
With 35C difference between the water and the CPU, is the waterblock is working properly? The thermal paste was spread thin with a razor blade, and the HK 3.0 tightened to spec. I'm thinking the single fan radiator isn't able to pull enough heat out of the system. Do I need to pony up the bucks for a bigger radiator or scrap it and go air?
