TOC T260 or TOC T260HD?
kompulsive
If I'm going to be using the monitor primarily for PC gaming, which should I get? Does the HD version sacrifice any PC gaming quality?
I bought the HD because I wanted to get rid of the bulky T.V. in my living room and use the monitor as my television when I'm not on the computer. If you're using the monitor exclusively for gaming I would go with the non-hd and save money, I think the only difference with the two models is the t.v. functionality of the HD.
the HD models have quite a bit higher input lag so for gaming the non hd ones are the way to go then you can always buy a tv tuner card if you want.
