So, I am looking to add another boxen to the farm purely for feeding three GPUs. The GPUs in question are currently in my i7 920 box and I'd like to yank them so I can reclaim 3m 40s on each frame of my -bigadv process.
The first thing that comes to mind is the P6N Diamond/Q6600 Combo that nitrobass24 is selling. It has way more CPU than I need for this task but I have a dual core box that could benefit from a CPU upgrade and the dual core would be just fine feeding the GPUs.
However, I recall there were some issues with folding on P6N Diamonds because of the 680i chipset but I don't recall exactly what it was. I think it was the inability to mix G92 and G200 GPUs but if you had all G200 GPUs you were fine. Does anyone remember?
For a truly low-budget approach, I am looking at the combo below. For brand new hardware, the price is yummy. I could probably do something similar for even cheaper if I search for used hardware. I know Zero82z uses this motherboard and is very happy with it.
