That_Sound_Guy
- Apr 29, 2002
Ok guys, as some of you have noticed the rollout for UT2004 has not gone well. However, they have found the cause of most problems and guess what it is the same as UT2003, the CD protection is causing it. Now I know the rules and hacks and cracks are not allowed to be talked about but in this case it actually allows you to play the damn game. There is a NOCD .exe file which fixes the problems but I accordance with the rules I cannot post the link to it. (But Im sure most can find it) I just wanted to spread the word to those having problems.
For the DVD version not installing. Some people disabled DMA mode for thier drive temporarily and it loaded fine. Just run the install, then re-enable DMA.
Reg Key to change CD Key (People are already stealing real ones) - HKEY_LOCAL_MACHINE\Software\Unreal Technology\Installed Apps\UT2004
For skipping and stutters in the game. -
Disabling Voice to Text features and Preload Player Skins has helped with the problem but an official cause is not known. I'll keep you posted on whats goin on with that.
Some gamers have noticed that if you change the sound detail from Software to Hardware it has significantly helped with the mouse lag issue. however if you have an old/weak sound card this could hurt performance overall at the same time. I tried it and I have a onboard Nforce 2 soundcard and things got a little better for me.[
