Basically, within the next month, I plan to build a computer based around a q6600, 4 GB PC6400 RAM and a 9800GTX. I will buy from eVGA so that I can step up to a new card in July when they come out.
Now, I can't decide between a couple options, which are:
1) Buy an eVGA 750i SLI FTW mobo, and throw another 9800GTX/step-up in in Decemberish.
2) Buy a non SLI mobo and just buy a new card next summer or something.
I know people normally say don't buy SLI if you don't plan on using it right away, since you won't use it and new tech will be out, but I almost think that adding another card by the end of 2008 will still be a legit idea.
Also, if you recommend a non-SLI mobo, what are your favourites? Looking at $200 max.
Thanks in advance.
Thanks in advance.
