kronchev said:Well, I had a T-line, and it works great, how its supposed to. However I fell in love with the Aqua Computers res and just bought one. It should get here in a few days. I assume itll be just as easy as the t-line, except itll be more restrictive on where I can put it in my case (its just displacing my t-line so its not a huge problem)
Dark Ember said:If you have a place to put it, can get it with the same tubing diameter you want, and don't mind spending the money, I would say to just go ahead and get one. It will most likely make your setup faster and easier.
I can't say this from first hand experience (and many people will disagree), but I have heard some pretty bad things about bay reservoirs, so you might want to take that into consideration if you plan on getting one.
lentic said:Well from personal experience bay res's always cause bubbles because u can never get all the air out.... however i don't know how much or what res u plan on buying but if u buy a tube res that stands up u can end up w/ bubbles but there is a real easy fix for this.
all u have to do is get a sponge ( not the organic kind) a very loosly packed synthetic kind.... i used the one that came w/ my ehime pump and stuck it in the top of my innovatek Tank-o-matic
rogue_jedi said:host thine own images.
that said, a res makes it a lot easier to fill/bleed a loop. another tip: unless your pump is good enough to draw water, put it at the bottom of your case with the res at the top to make sure the pump stays primed. that res looks good, just make sure you leak test for long enough.
acascianelli said:get the res, easy to fill, easy to bleed.
Deadlierchair said:I'm not exactly sure what people mean by "hearing bad things about a bay res." Does it mean they leak? They don't bleed well? That's the thing that confuses me. Overall, when designed well and leak tested it seems like they're just any other reservoir, except it slides into a bay.
I did make one mistake that you might like to know about. With my DD res I got the res itself, the attachments, and some little rubber O-rings. I installed the attachments and screwed them in as tight as possible over the O-rings. The problem is that that is not how they work. You want to tighten them a fair amount until the O-ring is firm but beyond that it pushes the O-ring out of the way and voids the seal.
I love my dual floppy, if it needs to be filled I just pull it out a bit and pour more water in. The dual 5.25" take up a lot of room but I guess you can choose according to your space requirements.
Morphes said:wonder why there are only 5 1/2" rez's you would think that a 3" one would be more of a useful thing as no one uses a floppy anymore
rogue_jedi said:i think deadlierchair is talking about a floppy bayres (unless he means some other "double floppy" )
Little Grabbi said:Is it just me, or are german companies taking over the US W/C market?
Personally, I'd definetely use a res, I've got one that attatches directly to my trusty old eheim, dubbed 'aquainlet', made by aqua-computer.
MrWoot said:i'm interested in getting started in watercooling... would it make sense to attach your res to the top of the case, drill a hole through the case, and have the res stick out the top?
Pecos said:That's my plan. I've got one of these on the way. Aqua Computers also has the AquaTube that looks very cool mounted on the top. I've read that they're a little restrictive though, not to mention a little pricey.
Pooky said:They aren't restrictive if you're using a 1/4" low flow system. That's what they're designed for anyway. Most Americans use 1/2" high flow systems, so if you're integrating it into that, it will be very restrictive. You could always take an Aquatube to a machine shop and have them re-bore the 1/4" holes to fit 1/2" NPT. You'll need to have that part anodized as well, cause the bare aluminum would casue corrosion with all the other copper pieces in the system. If you don't mind the restrcition, SNT Systems sells barbs that let you use 3/8" tubing with the Aquatube, as well as 1/2" barbs, but I don't think those one will fit because they thread into 1/4" BSPT, and the tube uses 1/8" instead.
Also peek at the Criticool Waterplant (www.criticool.com). It's a 4" or 6" acrylic tube you can use horizontally or vertically. That would look pretty good at the top of the case as well. It was my favortie ressy when I had a 1/2" system. This ressy is just like the Angel Eye above, but the threads are on the top and bottom instead of the sides.
anr11 said:So, which one did you end up getting exactly and how's it working out for you? I'm also trying to determine what to get for a res.
Little Grabbi said:Is it just me, or are german companies taking over the US W/C market?...
firtol88 said:LOL mostly just for those interested in silent PCs and quiet computing, IME most people interested in high overclocks are still using high flow, big rad...
Pooky said:I overclock and use little ID low flow. My friend has a big OC and uses little ID with low flow. They are just different styles, it's engineering versus brute force.
kronchev said:oh god
there is no "special engineering" with german blocks. AT ALL. weve talked about this on procooling, you know, the forum that actual block designers visit. german systems perform less, case closed. theyre NOT naturally quieter, theyre naturally better looking and more expensive. the only advantage over the american system is looks. THAT IS IT. I could build a just as quiet if not QUIETER system for half the price of a german system that performs better, but the tradeoff is it doesnt look *as good*
