So, I've found my 3000+ is stable up to 2655MHz (9x295) while my ram is deadset on stopping at 280MHz...at least with complete stability. I can loosen timings, increase voltage, do a voodoo dance, it still errors past 280. Now at 295htt, a 5/6 divider puts the memory at 241MHz, so my question to you guys is thus:
Should I use the divider, and run 39MHz slower, asynchronous ram and gain 135MHz (9x280=2520MHz) of processor speed, or should I stick with 280 for both the ram and cpu?
Or, should I bump the cpu voltage a smidge higher and try for 2.7GHz even, and use the mem divider?
