to all x-alien/super alien owners
i have heard that it has started comeing w/ scull grills, as aposed to the alien shaped ones. do all new ones(ie, past month or two) come w/ them? and how hard are the grills to change?
thank your in advance
I got my X-Alien Case like 4 months ago, it came with skull grills. Doesn't make a difference which ones it came with. Case is still awesome.
how are the grills atatched? how easy are they to change?(i dont like sculls, i do, however, like aliens or the "blade" ones you can get from new egg that have a cool reversing spiral in them)
It is very easy to change. There are four very intresting tabs which took me quite a while to figure out how to remove but when you push down on the button it releases the grill and fan from the case. If you want I can take a pic in a few hours after I get back, but its no problem to change
They're very easy to change. They have rubber push screws that absorb virbation and work nicely.
Mine look to be made of plastic, I haven't removed them becuase I don't want them to break.
Got mine last month from xtreme gear. I got the skull grills too, but just changed them to match my hsf grill. It was super easy, i have the black plastic rivity thingies. All you have to do is stick a little screwdriver into the back hole of the fan (where the screw would normally go if it was attached on the other side), then push the smaller part out of the inside of the pin. The button part on the outside should raise up a bit and you can pull them right out. I did it in like 5secs each and didn't break any.
